Hi all,
I am making a new Network Map and i faced one problem..
I want to make an element "Host Group", and assign it an image so it looks like a rectangle.
The idea is to use it as some kind of background for a couple of hosts belonging to that Host Group.
So, once i have that, i would create a host element pointing to the Zabbix Server, and create a link to the Host Group mentioned earlier.
The final configuration should be a couple of host on top of the image that represents the host group and a link to the zabbix server.
The problem is that when i put the hosts on top of the image, their labels ends behind the image, so they aren't visible.
Summing up, the question is, How can i manage to send front or back the elements in the map?
Here is an example of this problem.
I appreciate any help you can offer me.
Regards
Regards
