Zabbix interface URL parameters
  • xibbaz
    • Jun 2009
    • 74
    Is there a list somewhere of the supported parameters when accessing Zabbix interface thru URL.
    I have a couple (fullscreen, groupid, show_severity, ...) I'm missing something like "nodeid" to show subnodes also.
  • alixen
    • Apr 2006
    • 474
    I think that there is nothing about that in the documentation.
    When I need to know what parameters are supported by some URL, I check PHP source. They are described at the beginning of the file.
    For instance, in chart2.php allowed parameters are:
    //              VAR                     TYPE    OPTIONAL FLAGS  VALIDATION      EXCEPTION
            $fields=array(
                    'graphid'=>             array(T_ZBX_INT, O_MAND,        P_SYS,  DB_ID,          null),
                    'period'=>              array(T_ZBX_INT, O_OPT,         P_NZERO,        BETWEEN(ZBX_MIN_PERIOD,ZBX_MAX_PERIOD), null),
                    'stime'=>               array(T_ZBX_STR, O_OPT,         P_SYS,          null,           null),
                    'border'=>              array(T_ZBX_INT, O_OPT,         P_NZERO,        IN('0,1'),      null),
                    'width'=>               array(T_ZBX_INT, O_OPT,         P_NZERO,        '{}>0',         null),
                    'height'=>              array(T_ZBX_INT, O_OPT,         P_NZERO,        '{}>0',         null),
    Regards,
    Alixen
    http://www.alixen.fr/zabbix.html
