Snmp
  • benito103e
    • Jun 2010
    • 24
    Snmp
    My zabbix server works well but I'm trying to get back SNMP value from a server to my zabbix server.
    The problem is that I don't have snmpwalk command unable (for testing configuration) :
    -bash: snmpwalk: command not found
    I can install snmp library into my zabbix server, but why is it not present yet?? I make a
    ./configure --enable-server --enable-agent --with-pgsql --with-net-snmp --with-libcurl --with-jabber --prefix=/usr
    ... and it works
    Is there a probleme? or is it normal?
    Thanks a lot for your response
    And sorry for my "English"
  • Eddriks
    • Apr 2010
    • 22
    Hello !
    Have you install the snmp package?
    this will contain the different tools you need !!
    • benito103e
      • Jun 2010
      • 24
      Hi Eddriks,
      Thanks for your fast reply
      I Will install the package snmp ! But is it normal that I had not to install it before??
      Is it just
      I try to make a clean installation of my zabbix server.
      • Eddriks
        • Apr 2010
        • 22
        "normal" I don't think so..
        May be this package had been installed by dependencies of an other package!
        Good continuations!
        Eddriks.
