aggregate item
  • radamand
    • Aug 2008
    • 89
    aggregate item
    I'm trying to use an aggregate item but its not working, I keep getting "Not supported by Zabbix agent".
    I want to test the connectivity from a group of servers to a single web site (sams-web:80), and have the item collect the maximum response (0 if down, 1 if up).
    here's my aggregate item;
    grpmax["Archer","net.tcp.port[sams-web,80]","max","900"]
    am I doing something wrong? as an individual item this test works fine from each host.
  • richlv
    • Oct 2005
    • 3112
    is the item type set to be aggregated ?
    does host group exist, and do all hosts in it have an item with the exact same key ?
