help whit zabbix and sqlite and cherokee
  • mariag
    • Jun 2010
    good morning, i want install zabbix whit sqlite, but i have problems creating the database,
    i too need use whit web server cherokee, please if someone know how i can do? or gives me information I will be grateful. Thanks
  • richlv
    • Oct 2005
    • 3112
    it's suggested to use separate threads for separate questions.
    regarding sqlite, if you want to use zabbix server with sqlite, you have to create database manually. if it's zabbix proxy, you have to specify the path and db will be created automatically. see zabbix manual regarding manual (heh) sqlite database creation.
    http://www.zabbix.com/documentation/...#zabbix_server
    http://www.zabbix.com/documentation/...e#zabbix_proxy
