Item: Status
  • kurt
    • Aug 2005
    • 21
    Item: Status
    Howdee all you zabbix lovers. I have a problem with a key value. I`m using alpha10 and i was using the status key to monitor if the status of the agents running on windows machines.
    I decided to upgrade the database to beta2 using the correct procedures, but found out the status key didnt work. So therefore i downgraded back to alpha10 and the status key, still doesnt work.
    Has anybody come across this problem before?
    Help would be appreciated.
    K
