I'm trying to use an external check to verify JMX parameters. I'm using jmxclient in order to do it.
I've build a script like this:
/usr/lib/jvm/java/bin/java -jar /home/zabbix/jmxclient.jar usr: pass host: port $1 2>&1 | awk -F: '{print $NF}'
If I execute the script manually (as zabbix user) it will run like a charm:
./jmx.sh java.lang:type=Threading\ ThreadCount
So, I created a new item in zabbix:
Description:ThreadCount
Type: External check
Key: jmx.sh[java.lang:type=Threading\ ThreadCount]
The script is being called, but I'm receiving an error from jmxclient: Key properties cannot be empty
This error occurs when jmxclient isn't supplied with a mbean to query.
So, I'm guessing that my item isn't properly configured.
What is wrong with my item?
TIA,
Bob
TIA,
Bob
