Proxy and CentOS 5.4
  • syntaxcollector
    • Nov 2008
    Hi All
    I have a working Zabbix 1.8.2 server collecting data for our office and our colo facility. However the link between the colo and office is flaky. What I'm trying to do is setup a proxy on the colo side to have a 1 hour cache and relay the data to our primary server at the office. Our zabbix server is compiled from source and uses a mysql database
    I've followed the instructions found in the zabbix documentation to compile the proxy using a sqlite3 database. I add the proxy to zabbix under Administration->DM->Proxies. The zabbix server "sees" the proxy because the "last seen" field is always under 60s. However when I assign a colo host to the proxy I stop receiving data from it. The colo host's zabbix_agentd.log file says this:
     29343:20100622:124847 Timeout while answering request
     29343:20100622:124847 Getting list of active checks failed. Will retry after 60 seconds
    I also am unable to receive any SNMP data which is more important to me than the zabbix agent data. Has anyone had this problem before?
    Zabbix Server OS: CentOS5.4
    Zabbix Server Build: 1.8.2 from source
    Zabbix Proxy OS: CentOS5.4
    Zabbix Proxy Build: 1.8.2 from source
    P.S. The SQLite database on the zabbix proxy never gets any data written to it, it is identical to when I created it from the blank schema in zabbix-1.8.2/create/schema. (Yes I've checked the permissions)
    EDIT: and now I am receiving this in the log file
      2041:20100622:123131.760 Deleted 0 records from history [0.000994 seconds]
      2028:20100622:124131.671 Error while receiving answer from server [ZBX_TCP_READ() failed [Interrupted system call]]
