Fatal error
  • dunedin
    • Dec 2005
    • 12
    Fatal error
    I am running FC3, Kernel - 2.6.9, I installed zabbix on my machine but i get
    Fatal error: Call to undefined function: mysql_pconnect() in /var/www/html/include/db.inc.php on line 33
    when trying to execute http://localhost (or) http://ipaddress. phpinfo page works fine.
    The installed packages are :
    rpm -qa | grep php
    php-4.3.9-3
    php-mbstring-4.3.9-3
    php-ldap-4.3.9-3
    php-mysql-4.3.9-3
    php-ncurses-4.3.9-3
    php-pear-4.3.9-3
    php-devel-4.3.9-3
    php-snmp-4.3.9-3
    php-gd-4.3.9-3
    rpm -qa | grep MySQL
    MySQL-client-4.0.26-0
    MySQL-server-4.0.26-0
    MySQL-devel-4.0.26-0
    rpm -qa | grep httpd
    httpd-suexec-2.0.52-3
    system-config-httpd-1.3.1-1
    httpd-2.0.52-3
    httpd-manual-2.0.52-3
    apache and mysql are running.
    tried searching the forum, installed necessary package as said in the forum, but no luck.Can anyone advise ?
  • James Wells
    • Jun 2005
    • 664
    Greetings,
    Right off the bat, I suspect that you need to modify your php.ini to load the mysql.so extension.
    Unofficial Zabbix Developer
    • dunedin
      • Dec 2005
      • 12
      Thanks for your reply.
      mysql.so extension is already loaded in php.ini. any other suggestion ?
      • jcrm
        • Jun 2005
        Originally posted by http://www.google.co.uk/search?q=%22Call+to+undefined+function%3A+mysql_pc onnect%22
        Try this....
        In your php.ini:
        [MySQL]
        ; Allow or prevent persistent links.
        mysql.allow_persistent = On
        This will set to 'on' for mysql.allow_persistent, ok but is mysql
        enabled.
        alternativly edit the file referenced in the error, and change mysql_pconnect to mysql_connect
        • elkor
          • Jul 2005
          • 299
          what does the output of phpinfo say about mysql availability?
