I have a trigger/web-check that looks like this
{www1.toronto.terida.net:web.test.fail[Atlas English].max(#3)}#0
Its job is to check a website. It runs every 10 seconds and if I get 3 failures in a row, It should trigger. I've been getting alot of notices latley that its down, but if I check in my Apache logs, I can see the hits coming in just fine, so I dug deeper into my postgresql tables.
select * from items where key_ = 'web.test.fail[Atlas English]';
To get my item id.. and then..
zabbix=# select to_timestamp(clock),value from history_uint where value = 1 and itemid = 22283 order by clock desc limit 10;
to_timestamp | value
2010-06-28 13:15:31-04 | 1
2010-06-25 12:59:51-04 | 1
2010-06-22 14:49:48-04 | 1
2010-06-22 14:49:38-04 | 1
2010-06-22 14:49:28-04 | 1
2010-06-22 14:49:18-04 | 1
2010-06-22 14:49:08-04 | 1
2010-06-22 14:48:58-04 | 1
2010-06-22 14:46:52-04 | 1
2010-06-22 14:46:42-04 | 1
Now as you can see, on today the 28th and A few days ago the 25th, it only happened once. However on both of those days, I got a notice. Also on the 25th, I can recall the actual down time, it was me restarting apache for a configuration change.
Idea's? Is my Trigger syntax wrong?
Jeff.
Jeff.
