Zabbix Installation: data.sql script
  • fleguay
    • Jul 2010
    Hi all,
    I have installed the database and created ths schema. I tried to run data.sql for an oracle databse but several times I have those questions:
    Enter value for lt:
    Enter value for gt:
    What are those values used for and what should I put ?
    Thanks.
  • KhaineVII
    • Jul 2010
    I'm having the same problem, what I have to answer to these questions?
    Thanks in advance
    • fleguay
      • Jul 2010
      To correct this issue, you will need to type on the sqlplus session this command
      SET DEFINE OFF
      and then launch the sql script
      Regards
