how to test zabbix send email ?
  • molmi
    • Jul 2010
    • 39
    i'm installed zabbix aplliance in VMWare 2.0.2 ... how to test send email how is log to check?
    thanks
  • ruswold
    • Mar 2010
    • 210
    thanks
    Very simple
    1. make mail config (smtp server and other)
    2. add email in profile your's user
    3. make simple trigger
    4. make action trigger to send email
    • molmi
      • Jul 2010
      • 39
      thanks!
      where i found a documentation for configure trigger ?
      • ruswold
        • Mar 2010
        • 210
        thanks!
        http://www.zabbix.com/documentation/...onfig/triggers
        • molmi
          • Jul 2010
          • 39
          thank you!!!!!!
          But how can I test that the parameter to the mail server is correct?
          • ruswold
            • Mar 2010
            • 210
            thank you!!!!!!
            I don't know how test, but if parameter is wrong you don't receive a mail and you can check zabbix log, monitoring-(events)triggers from web interface
