{HOSTNAME} macro in action returns wrong value
  • probert100
    • Jun 2010
    I just upgraded to version 1.8.2 from 1.6. I have noticed that the {HOSTNAME} macro returns wrong value when action is trigged / email notification is send. When you use HOSTNAME value of the TRIGGER.NAME is returned
    For example this action:
    Notification Severity: {TRIGGER.SEVERITY}
    Device: {HOSTNAME}
    Device Status: {STATUS}
    Event Time: {EVENT.DATE} - {EVENT.TIME}
    Trigger ID: {TRIGGER.ID}
    Trigger Key: {TRIGGER.KEY}
    INFO:
    {TRIGGER.NAME}: {STATUS}
    Will generate email that looks like:
    Notification Severity: High
    Device: Port 5 Input Errors
    Device Status: OK
    Event Time: 2010.07.11 - 08:01:43
    Trigger ID: 44368
    Trigger Key: 86801
    INFO:
    Port 5 Input Errors Serial0/0/0:0 Input Error: OK
    Thanks for any help!
  • probert100
    • Jun 2010
    I wonder if anyone could give me some direction debugging this.
    Is this the src file that contains the Macro substitution?:
    libs/zbxserver/expression.c
    Thanks!!
