Understanding Zabbix Trigger max / min value for a period of time
  • Tarsinion
    • Aug 2009
    • 28
    Hi guys,
    i just want to get a message if a value is 0 for a period of time. As far as i understand "{test:tcp,10050.min(300)}=0" would do the job?!
    ... but unfortunately its not :-) the action is immediately triggered.
    What do i do wrong?
  • alixen
    • Apr 2006
    • 474
    Originally posted by Tarsinion
    Hi guys,
    What do i do wrong?
    If you use min, a single value is enough to raise the trigger.
    If you want ALL values to be 0, it need to use max function.
    Regards,
    Alixen
    http://www.alixen.fr/zabbix.html
    • Tarsinion
      • Aug 2009
      • 28
      Translated its:
      "maximum value within 300 seconds must be 0?"
      to easy to be true ... thanks for your perfect and fast help.
