Helle everyone,
yes I know this is an neverending story but please, I need help for the active agent check :-)
For begining a simple example-scenario.
I have a client (ip:192.168.1.50/ name: testclient) and the zabbix server is 192.168.1.200 with the name zabbixserver
It is an windows environment. I use the setup-installtion-tool for the agent.
Now I want to edit the agent`s file, but I don`t exactly know which line I have to edit, or have I to uncommend the lines ?
perhaps you could tell me which lines I habe to edit to get an active agent, and how I can setup the active agent in zabbix.
here is the agent-file:
# This is a config file for Zabbix Agent (Windows)
# To get more information about Zabbix, go to http://www.zabbix.com
### Option: DebugLevel
# Specifies debug level
# 0 - no debug
# 1 - critical information
# 2 - error information
# 3 - warnings
# 4 - for debugging (produces lots of information)
# Mandatory: no
# Default:
DebugLevel=0
### Option: LogFile
# Name of log file.
# Mandatory: no
# Default:
# LogFile=
LogFile=C:\Programme\Zabbix Agent\Zabbix_agentd.log
### Option: LogFileSize
# Maximum size of log file in MB.
# 0 - disable automatic log rotation.
# Mandatory: no
# Range: 1-1024
# Default:
# LogFileSize=1
### Option: SourceIP
# Source IP address for outgoing connections.
# Mandatory: no
# Default:
# SourceIP=
### Option: EnableRemoteCommands
# Whether remote commands from Zabbix server are allowed.
# 0 - not allowed
# 1 - allowed
# Mandatory: no
# Default:
EnableRemoteCommands=0
##### Passive checks related
### Option: Server
# List of comma delimited IP addresses (or hostnames) of Zabbix servers.
# No spaces allowed. First entry is used for receiving list of and sending active checks.
# Note that hostnames must resolve hostname->IP address and IP address->hostname.
# Mandatory: yes
# Default:
# Server=
Server=192.168.1.206
### Option: Hostname
# Unique hostname.
# Required for active checks and must match hostname as configured on the server.
# Default:
# Hostname=system.uname
Hostname=testclient
### Option: ListenPort
# Agent will listen on this port for connections from the server.
# Mandatory: no
# Range: 1024-32767
# Default:
ListenPort=10050
### Option: ListenIP
# Agent will listen on the specified interface.
# Mandatory: no
# Default:
# ListenIP=0.0.0.0
# ListenIP=127.0.0.1
### Option: DisablePassive
# Disable passive checks. The agent will not listen on any TCP port.
# Only active checks will be processed.
# 0 - do not disable
# 1 - disable
# Mandatory: no
# Default:
# DisablePassive=0
##### Active checks related
### Option: DisableActive
# Disable active checks. The agent will work in passive mode listening for server.
# Mandatory: no
# Default:
# DisableActive=0
# DisableActive=1
### Option: ServerPort
# Server port for retrieving list of and sending active checks.
# Mandatory: no
# Default:
ServerPort=10051
### Option: RefreshActiveChecks
# How often list of active checks is refreshed, in seconds.
# Mandatory: no
# Range: 60-3600
# Default:
# RefreshActiveChecks=120
### Option: BufferSend
# Do not keep data longer than N seconds in buffer.
# Mandatory: no
# Range: 1-3600
# Default:
# BufferSend=5
### Option: BufferSize
# Maximum number of values in a memory buffer. The agent will send
# all collected data to Zabbix Server or Proxy if the buffer is full.
# Mandatory: no
# Range: 1-65535
# Default:
# BufferSize=100
### Option: MaxLinesPerSecond
# Maximum number of new lines the agent will send per second to Zabbix Server
# or Proxy processing 'log' and 'eventlog' active checks.
# The provided value will be overridden by the parameter 'maxlines',
# provided in 'log' or 'eventlog' item key.
# Mandatory: no
# Range: 1-1000
# Default:
# MaxLinesPerSecond=100
############ ADVANCED PARAMETERS #################
### Option: StartAgents
# Number of pre-forked instances of zabbix_agentd that process passive checks.
# Mandatory: no
# Range: 1-16
# Default:
StartAgents=5
### Option: Timeout
# Spend no more than Timeout seconds on processing
# Mandatory: no
# Range: 1-30
# Default:
# Timeout=3
### Option: Include
# You may include individual files or all files in a directory in the configuration file.
# Mandatory: no
# Default:
# Include=
# Include=c:\zabbix\zabbix_agent.userparams.conf
# Include=c:\zabbix\zabbix_agentd\
### Option: UserParameter
# User-defined parameter to monitor. There can be several user-defined parameters.
# Format: UserParameter=<key>,<shell command>
# Note that shell command must not return empty string or EOL only.
# Example: UserParameter=system.test,echo 1
#UserParameter=system.test,echo 1
# 0 - no debug
# 3 - warnings
# Mandatory: no
# Default:
DebugLevel=0
### Option: LogFile
# Name of log file.
# Mandatory: no
# Default:
# LogFile=
# Mandatory: no
# Range: 1-1024
# Default:
# LogFileSize=1
# Mandatory: no
# Default:
# SourceIP=
# 0 - not allowed
# 1 - allowed
# Mandatory: no
# Default:
### Option: Server
# Mandatory: yes
# Default:
# Server=
# Unique hostname.
# Default:
Hostname=testclient
# Mandatory: no
# Range: 1024-32767
# Default:
ListenPort=10050
# Mandatory: no
# Default:
# ListenIP=0.0.0.0
# 1 - disable
# Mandatory: no
# Default:
# DisablePassive=0
# Mandatory: no
# Default:
# DisableActive=0
# DisableActive=1
# Mandatory: no
# Default:
ServerPort=10051
# Mandatory: no
# Range: 60-3600
# Default:
# Mandatory: no
# Range: 1-3600
# Default:
# BufferSend=5
# Mandatory: no
# Range: 1-65535
# Default:
# BufferSize=100
# Mandatory: no
# Range: 1-1000
# Default:
# Mandatory: no
# Range: 1-16
# Default:
StartAgents=5
### Option: Timeout
# Mandatory: no
# Range: 1-30
# Default:
# Timeout=3
### Option: Include
# Mandatory: no
# Default:
# Include=
