Assist defining Trigger
  • datasheet
    • Jul 2010
    Zabbix Version: 1.8.2
    I have one script that I run against my Oracle Database
    The script just find a tablespace that is 97% used.
    Result:
    Tablespace PERCENT_USED
    USERS 97
    I just want a trigger that will fire when we found any tablespace that is 97% used.
    I am using system.run[command] and it is working just fine but i am unable to define a proper function on trigger.
    Any suggestion?
  • jerrylenk
    • May 2010
    • 62
    Originally posted by datasheet
    Result:
    USERS 97
    I understand your script returns the above result as text?
    Then you would need some RegularExpression that matches "97", "98", "99" or "100", but that sounds complicated. I am not into regex though. Perhaps it isn't.
    Easier, IMHO, would be modifying the script to print out only the Number, or writing a wrapper script to strip everything but the Number.
    Then your trigger expression would look like:
    {your.host:system.run[<your_script>,wait].last(0)}>=97
