Hi there,
I would like to integrate some Zabbix monitoring in my own php application and had good luck with the "old" XML protocol described in the docs.
But if I checked a tcpdump from zabbix_sender, I figured it's using JSON.
Is this somewhere documented so I can do this in a similar way from php?
Thanks.
--Michael
Thanks.
--Michael
