Trigger name or trigger comments with macro's
  • subba5678
    • May 2010
    • 132
    #16
    I want to monitor and create a trigger for the Windows CPU Utilization ,Can you please post me the Parameter for the CPU Utilization {system.cpu.util } using this template for 30 Mins and for the of threshold 95%
    Subbu
    • bashman
      • Dec 2009
      • 432
      #17
      Subbu
      You can use for Windows:
      perf_counter[counter,<interval>]
      Value of any performance counter, where “counter” is the counter path, and “interval” is the time period for storing the average value.
      Return is the Average value of the “counter” during last “interval” seconds. Default value, if not given, for “interval” is 1.
      Performance Monitor can be used to obtain list of available counters. Until version 1.6 this parameter will return correct value only for counters that require just one sample (like \System\Threads). It will not work as expected for counters that require more that one sample - like CPU utilisation. Since 1.6 interval is used, so the check returns an average value for last “interval” seconds every time.
      For Linux:
      system.cpu.util[<cpu>,<type>,<mode>]
      cpu - CPU number (default is all CPUs)
      type - one of idle, nice, user (default), system, kernel, iowait, interrupt, softirq, steal
      mode - one of avg1 (default),avg5 (average within 5 minutes), avg15
      You can read the online documentation:
      http://www.zabbix.com/documentation/...l/config/items
      978 Hosts / 16.901 Items / 8.703 Triggers / 44 usr / 90,59 nvps / v1.8.15
      • subba5678
        • May 2010
        • 132
        #18
        Hi ,
        Thanks for the reply ,As per your sugesstion I created an item with Zabbix Active Agent and i am not getting any alert . I am using the below parameter .Please help me out.
        Key
        system.cpu.util[,user,avg1]
        Trigger Expression
        BLR-NOC-06:system.cpu.util[,user,avg1].last(0)}>20
        Thanks,
        Subbu
        • bashman
          • Dec 2009
          • 432
          #19
          Hi ,
          You need an action with condition Trigger value = "PROBLEM" and your email subject and message configured.
          Key
          Trigger Expression
          Thanks,
          Subbu
          The item key and trigger expression is correct. This will be triggered when cpu (user time) is over 20%.
          • subba5678
            • May 2010
            • 132
            #20
            I created a Group Called As " DFW " in that group i added the host. I am getting all the alerts from this Group (Disk , Host Status ,Memory e.tc.) but I am not getting the alerts only related System Cpu Utilization by using the below Paramaeter . If i am wrong with this please help me out ..
            Thanks,
            Subbu
            • bashman
              • Dec 2009
              • 432
              #21
              Thanks,
              Subbu
              Every thing seems fine, may be it's not triggering because user time cpu is not reaching 20%
              • subba5678
                • May 2010
                • 132
                #22
                Hi ,
                If I want want to test the Parameter Can you please tell me how i can test it as cz after testing the parameter we are taking to like production
                Thanks,
                Subbu
                • bashman
                  • Dec 2009
                  • 432
                  #23
                  Go to Monitoring > Triggers, select Host Group and Host and look out for your trigger, if you can see your trigger, it means it has triggered, but message wasn't received. Otherwise if you can't see it, you're not getting message because it didn't trigger.
                  • subba5678
                    • May 2010
                    • 132
                    #24
                    Thanks for the quick reply , I didn't see any trigger in the below specified Path , and more over i logged into the system as User (test) , I am trying to check with the same parameter by giving low threshold (1) . i guess this can help me out.
                    BLR-NOC-06:system.cpu.util[,user,avg1].last(0)}>1
                    Thanks,
                    Subbu
                    • subba5678
                      • May 2010
                      • 132
                      #25
                      Hi ,
                      Still i didn't get any trigger as my CPU Utilization is more that 1 . For reference please find the attachment of the screen Shot , Please help me out
                      Thanks,
                      Subbu
                      • bashman
                        • Dec 2009
                        • 432
                        #26
                        For Windows Servers try this item key:
                        perf_counter["\Processor(_Total)\% Processor Time"]
                        And this trigger expression:
                        BLR-NOC-06:perf_counter["\Processor(_Total)\% Processor Time"].last(0)}>1
                        This would trigger when cpu reaches more than 1%.
                        • subba5678
                          • May 2010
                          • 132
                          #27
                          Its Awsome , It really helped me a lot now i am getting the Triggers if the CPU Usage goes more than 1 . i want to trigger the same if the CPU Usage goes more than 95% for 5 minutes for that Can I use this Paramater , If not please help me out . Also please find the attchment of the Alert which I got For CPU Usage 1%
                          {BLR-NOC-06erf_counter["\Processor(_Total)\% Processor Time"].avg(300)}>90--------------PARAMETER For 5 Mins
                          Alert for CPU Utilization Greater than 1
                          Windows Server - on BLR-NOC-06 - Windows System Information on BLR-NOC-06: PROBLEM
                          Status: PROBLEM
                          Host: BLR-NOC-06 (172.25.100.183)
                          Severity: High
                          Last Item Value:
                          23 %
                          Thanks,
                          Subbu
                          • bashman
                            • Dec 2009
                            • 432
                            #28
                            Great news!, and yes you can use this:
                            Or:
                            {BLR-NOC-06:perf_counter["\Processor(_Total)\% Processor Time"].min(300)}>95
                            Which is your polling interval?, if you have a 60 seconds interval, you can use also for 5 minutes:
                            {BLR-NOC-06:perf_counter["\Processor(_Total)\% Processor Time"].avg(#5)}>90
                            Your message is great:
                            Status: PROBLEM
                            Severity: High
                            Last Item Value:
                            23 %
                            Thanks,
                            Subbu
                            Here is another example:
                            Subject:
                            {HOSTNAME}: {TRIGGER.SEVERITY} {STATUS}
                            message:
                            PROBLEM: {TRIGGER.NAME}
                            STATE: {STATUS}
                            MONITOR: {ITEM.NAME}
                            HOST: {HOSTNAME} ({IPADDRESS})
                            SEVERITY: {TRIGGER.SEVERITY}
                            LAST VALUE: {ITEM.LASTVALUE}
                            INITIAL PROBLEM TIME: {EVENT.DATE} - {EVENT.TIME}
                            COMMENTS:
                            {TRIGGER.COMMENT}
                            NOTIFICATION HISTORY:
                            {ESC.HISTORY}
                            EXTRA INFO:
                            MAX 1': {{HOSTNAME}:{TRIGGER.KEY}.max(60)}. MIN 1': {{HOSTNAME}:{TRIGGER.KEY}.min(60)}.
                            MAX 5': {{HOSTNAME}:{TRIGGER.KEY}.max(300)}. MIN 5': {{HOSTNAME}:{TRIGGER.KEY}.min(300)}.
                            MAX 15': {{HOSTNAME}:{TRIGGER.KEY}.max(900)}. MIN 15': {{HOSTNAME}:{TRIGGER.KEY}.min(900)}.
                            Average value 15': {{HOSTNAME}:{TRIGGER.KEY}.avg(900)}.
                            EVENTO ID: {EVENT.ID}. TRIGGER ID: {TRIGGER.ID}
                            GROUP LINUX ALERTS. LINK: http://XXX.XX.XX.XXX/zabbix/
                            • subba5678
                              • May 2010
                              • 132
                              #29
                              Hi bashman ,
                              I Cant Express my happiness with the Words I feel Great with your Wonderful Help Which helped me to monitor the Windows Servers and Also i will use the Same Template for Linux Servers . As of now i will monitor the basic Stuff and will start monitoring the mysql query , if i am not able to do that i will get back to you .
                              My HeartFull Thanks to you
                              Thanks and Regards,
                              Subbu
                              • bashman
                                • Dec 2009
                                • 432
                                #30
                                Hi bashman ,
                                Thanks and Regards,
                                Subbu
                                Remember to use something like this:
                                {T-Linux-OS:system.cpu.util[,idle,avg1].avg(900)}<10
                                for the Linux Servers. If you want a Linux or Windows template I can attach you my templates in XML format, but they are in Spanish.
                                For MySQL Server you can use the UserParameters agent items:
                                #UserParameter=mysql.ping,mysqladmin -uroot ping|grep alive|wc -l
                                #UserParameter=mysql.uptime,mysqladmin -uroot status|cut -f2 -d":"|cut -f1 -d"T"
                                #UserParameter=mysql.threads,mysqladmin -uroot status|cut -f3 -d":"|cut -f1 -d"Q"
                                #UserParameter=mysql.questions,mysqladmin -uroot status|cut -f4 -d":"|cut -f1 -d"S"
                                #UserParameter=mysql.slowqueries,mysqladmin -uroot status|cut -f5 -d":"|cut -f1 -d"O"
                                #UserParameter=mysql.qps,mysqladmin -uroot status|cut -f9 -d":"
                                #UserParameter=mysql.version,mysql -V
                                And:
                                UserParameter=mysql.users,us=$(mysqladmin proc stat -u zabbix|wc -l);let us=$us-5;echo $us
                                UserParameter=mysql.slowquery,mysqldumpslow /var/log/mysql/mysql-slow.log
                                UserParameter=mysql.general,mysqladmin proc stat -u zabbix
                                UserParameter=mysql.aborted_connects,typeset -i ca=$(mysql -u zabbix --execute="SHOW STATUS LIKE 'Aborted_connects'" --skip-column-names|awk '{print $2}'); echo $ca
                                UserParameter=mysql.threads_connected,typeset -i tc=$(mysql -u zabbix --execute="SHOW STATUS LIKE 'Threads_connected'" --skip-column-names|awk '{print $2}'); echo $tc
                                Template example:
                                Description          Type          Key                   Type of information Units      Update interval Store value  History    Trends      Applications
                                Mysql/Ping.          ZABBIX agent  mysql.ping            Numeric (integer)              300             As Is        7          365         Mysql
                                Mysql/Uptime.        ZABBIX agent  mysql.uptime          Character                      7200            As Is        7          365         Mysql
                                Mysql/Threads.       ZABBIX agent  mysql.threads         Numeric (integer)              600             As Is        7          365         Mysql
                                Mysql/Questions.     ZABBIX agent  mysql.questions       Numeric (integer)              600             As Is        7          365         Mysql
                                Mysql/Slowqueries.   ZABBIX agent  mysql.slowqueries     Numeric (integer)              7200            As Is        7          365         Mysql
                                Mysql/Qps.           ZABBIX agent  mysql.qps             Numeric (integer)              600             As Is        7          365         Mysql
                                Mysql/Version.       ZABBIX agent  mysql.version         Character                      7200            As Is        7          365         Mysql
                                Mysql/Users.         ZABBIX agent  mysql.users           Numeric (integer)              600             As Is        7          365         Mysql
                                Mysql/General.       ZABBIX agent  mysql.general         Text                           900             As Is        7          365         Mysql
                                Mysql/Slowquery.     ZABBIX agent  mysql.slowquery       Text                           7200            As Is        7          365         Mysql
                                Feel free you ask.
