sound alert
  • nima0102
    • May 2010
    • 106
    sound alert
    Hi
    Is it possible to configure zabbix when one trigger is fired, those operators have open panel of zabbix (first page) get sound alert?
    Thanks in advance
  • sarathyme
    • Mar 2009
    • 58
    Sound alert is available only in Monitoring -> Triggers page.
    (Based on priority sound varies. Sounds wave files are located in audio directory of the frontend)
    (fyi, It will not play sound when you are in Monitoring -> Dashboard page)
    Regards
    Vijay
    • richlv
      • Oct 2005
      • 3112
      that will be possible in zabbix 1.8.3 - for more detail see http://www.zabbix.com/documentation/..._notifications
      • nima0102
        • May 2010
        • 106
        Thanks for your attention.
        I am very happy for good developing
        • nima0102
          • May 2010
          • 106
          Hi again.
          I have updated to 1.8.3.but sound alert icon is not in dashboard!
          Is there any setting to enable that on dashboard?
          Thanks in advance
          • richlv
            • Oct 2005
            • 3112
            this is enabled globally on zabbix frontend - see the linked page for details
            • nima0102
              • May 2010
              • 106
              After enable GUI Messaging in profile, I do not see any ICON on dashboard or trigger pages!
              Is there nay setting for this?
              Thanks in advance
              • richlv
                • Oct 2005
                • 3112
                any new incoming messages will pop up in the upper right corner - see the screenshot or create some problem
                • victorhugopa
                  • Apr 2010
                  • 66
                  The only way in 1.8.3 to enable sound alerts in triggers page is enabling the GUI Messaging?
                  • richlv
                    • Oct 2005
                    • 3112
                    as far as i know, yes
