Hi---I am trying to monitor HP compaq servers. They are unning redhat linux. I have installed HP sight support pack and configured snmp on the server. but zabbix is unable to monitor the servers. In the log file for zabbix server I am getting the following errors. Can someone please help me with this. Thanks.
Hp compaq server monitoring
l.local:HPenclosureRollupStatus0.1] error: OID [.1.3.6.1.4.1.232.3.2.3.1.1.11.0.1] value has unknown type [0x80]
30127:20100727:102219.358 Item [server:sensor[temp1]] error: Not supported by Zabbix Agent
30127:20100727:102219.359 Item [server:HPcontrollerRollupStatus.2] error: OID [.1.3.6.1.4.1.232.3.2.2.1.1.6.1] value has unknown type [0x80]
30131:20100727:102219.941 Item [server:HPcontrollerRollupStatus.1] error: OID [.1.3.6.1.4.1.232.3.2.2.1.1.6.0] value has unknown type [0x80]
30128:20100727:102221.386 Item [server:HPsystemStateCoolingUnitStatusCombined] error: OID [.1.3.6.1.4.1.232.6.2.6.1.0] value has unknown type [0x80]
30127:20100727:102223.115 Item [server:HPsystemStateChassisStatus] error: OID [.1.3.6.1.4.1.232.2.1.3.0] value has unknown type [0x80]
30130:20100727:102223.405 Item [server:HPenclosureRollupStatus1.1] error: OID [.1.3.6.1.4.1.232.3.2.3.1.1.11.1.1] value has unknown type [0x80]
30131:20100727:102223.628 Item [server:HPenclosureRollupStatus1.2] error: OID [.1.3.6.1.4.1.232.3.2.3.1.1.11.1.2] value has unknown type [0x80]
30129:20100727:102225.148 Item [server:sensor[temp3]] error: Not supported by Zabbix Agent
30129:20100727:102225.148 Item [server:HPenclosureRollupStatus0.2] error: OID [.1.3.6.1.4.1.232.3.2.3.1.1.11.0.2] value has unknown type [0x80]
30129:20100727:102229.070 Item [server:HPsystemStateGlobalSystemStatus] error: OID [.1.3.6.1.4.1.232.6.1.3.0] value has unknown type [0x80]
30130:20100727:102230.184 Item [server:HPsystemStateMemoryDeviceStatusCombined] error: OID [.1.3.6.1.4.1.232.6.2.14.4.0] value has unknown type [0x80]
30127:20100727:102232.301 Item [server:HPsystemStateTemperatureStatusCombined] error: OID [.1.3.6.1.4.1.232.6.2.6.3.0] value has unknown type [0x80]
30131:20100727:102232.417 Item [server:HPsystemStatePowerSupplyStatusCombined] error: OID [.1.3.6.1.4.1.232.6.2.9.1.0] value has unknown type [0x80]
