Need some help configuring zabbix to go over an XML and get values of it to insert in to the DB.
Basically we have a product that we can use "get" to a URL that will return an XML with various values, I need a way to have zabbix go to that URL get the XML and parse different values off of it.
Something like this
point the browser to:
will get me this:
<result>
<status result="OK">
<description code="1" status="OK">running</description>
</status>
<info>
<dock id="01">
<description>dock 01</description>
<location>Lab</location>
</dock>
<cradle index="1">
<description>Cradle 01</description>
<access>0101</access>
<video>
<recording>false</recording>
<streaming>true</streaming>
<PauseVideo>true</PauseVideo>
<HasAudio>true</HasAudio>hssId_DEXTER-cradle_0101-569D87A3</video>
<audio>XXXXXXXXX 1010LT 3/4</audio>
<hssid>XXXXXX</hssid>
<status code="1">running</status>
</cradle>
<Version>
<name>Atlantis</name>
<iteration_code>21</iteration_code>
<build_number>661</build_number>
<build_date>2010-07-25_06-02-08</build_date>
<build_time>2010-07-25_06-02-08</build_time>
<build_version>2010-07-25_06-02-08.661</build_version>
<dev_version>atlantis21-SNAPSHOT</dev_version>
<build_timestamp>1280027158360</build_timestamp>
<scm_version>31684</scm_version>
</Version>
<handset>
<manufacturer>XXXX XXXXXXXXX</manufacturer>
<model>SXXXX XXXXXXXXX W850</model>
<version>XXXXXXX 060831 2039 XX_GENERIC_CY</version>
<imei>XXXXXXXXXXXXXXX</imei>
<imsi>UNKNOWN</imsi>
<client-version>UNKNOWN</client-version>
<template-data>
<model>XXXXX</model>
<distributor>XXXX XXXXXXXXX</distributor>
<version>XXXXXXX 060831 2039 XX</version>
</template-data>
</handset>
</info>
<time64>
<time>1280240509</time>
<millitm>940</millitm>
<timezone>-120</timezone>
<dstflag>1</dstflag>
</time64>
<req_time>183425621</req_time>
<duration>234</duration>
<sys_start_time>Sun Jul 25 14:24:52 2010</sys_start_time>
<sys_uptime>2 days 02:56:57</sys_uptime>
<camera initialized="true" type="Pixelink">
<settings>
<fps>6</fps>
<rotate>0</rotate>
<roi>
<x>48</x>
<y>256</y>
<w>792</w>
<h>632</h>
</roi>
<sn>774001102</sn>
<feature id="FEATURE_WHITE_BAL">
<param>3200.000000</param>
<flags>2</flags>
</feature>
<feature id="FEATURE_SATURATION">
<param>150.000000</param>
<flags>2</flags>
</feature>
<feature id="FEATURE_GAMMA">
<param>2.200000</param>
<flags>18</flags>
</feature>
<feature id="FEATURE_SHUTTER">
<param>0.145000</param>
<flags>2</flags>
</feature>
<feature id="FEATURE_GAIN">
<param>4.080000</param>
<flags>2</flags>
</feature>
<feature id="FEATURE_FRAME_RATE">
<param>6.000000</param>
<flags>2</flags>
</feature>
<feature id="FEATURE_FLIP">
<param>0.000000</param>
<flags>514</flags>
</feature>
<feature id="FEATURE_WHITE_SHADING">
<param>1.523438</param>
<param>1.000000</param>
<param>1.437500</param>
<flags>2</flags>
</feature>
</settings>
<statistics>
<window>10</window>
<fps>6</fps>
<min_frame_time>125</min_frame_time>
<max_frame_time>172</max_frame_time>
<avg_frame_time>165.616669</avg_frame_time>
<bad_frames>0</bad_frames>
<bad_frames_percent>0.000000</bad_frames_percent>
<delayed_frames>0</delayed_frames>
<delayed_frames_percent>0.000000</delayed_frames_percent>
<min_delayed_frame_time>0</min_delayed_frame_time>
<avg_delayed_frame_time>0.000000</avg_delayed_frame_time>
</statistics>
</camera>
</result>
Any help would be appreciated
Something like this
will get me this:
<result>
</status>
<info>
<dock id="01">
</dock>
<cradle index="1">
<video>
</cradle>
<Version>
</Version>
<handset>
<template-data>
</template-data>
</handset>
</info>
<time64>
</time64>
<settings>
<fps>6</fps>
<rotate>0</rotate>
<roi>
<x>48</x>
<y>256</y>
<w>792</w>
<h>632</h>
</roi>
<sn>774001102</sn>
<flags>2</flags>
</feature>
<flags>2</flags>
</feature>
<flags>18</flags>
</feature>
<flags>2</flags>
</feature>
<flags>2</flags>
</feature>
<flags>2</flags>
</feature>
<flags>514</flags>
</feature>
<flags>2</flags>
</feature>
</settings>
<statistics>
<window>10</window>
<fps>6</fps>
</statistics>
</camera>
</result>
