how can discovery network in b class ?? ipv4??
  • molmi
    • Jul 2010
    • 39
    I need to monitor a network in b class 10.0.x.x mask 255.255.0.0
    I have configured in discover this parameters but not work can you help me?
    ip range ...10.0.0.1/16
    Thanks!
  • sarathyme
    • Mar 2009
    • 58
    I dont think ip class would have some effect here.
    Can you plz provide the screen snap of the discovery rule created?
    Regards
    Vijay
    • molmi
      • Jul 2010
      • 39
      • sarathyme
        • Mar 2009
        • 58
        I am not sure we can leave the key field blank.
        Please try adding the key as system.uname
        (I tried without key it did not work for me, adding the key discoverd)
        The Server will ask this item value from agent. This value can then be used to frame action conditions, like Windows devices to be added to Windows group etc. Agent would need the key to send give its value.
        Also increase the Delay to say 120 (10 secs should not cause any harm, but its too low to set for discovery )
        Regards
        Vijay
        • molmi
          • Jul 2010
          • 39
          but with system.uname parameter work with default action for discovery ? or I add anothe key?
          Very Thanks!
          • molmi
            • Jul 2010
            • 39
            thankyou work !
