Help with DM central node
  • jzuilkowski
    • May 2010
    On my central node, I have no hosts/templates, etc configured. The only thing the central node contains are the actions.
    All of the templates, items, triggers reside on the chiled nodes.
    It was my understanding that the child node would send trigger events up to it's master. This appears to not be happenning as none of my actions get engaged and i see no history anywhere.
    HELP!
    Here's a snip of the central node's log file:
    13780:20100729:135125.186 NODE 1: Received history from node 3 for node 3 datalen 324916
    13781:20100729:135126.901 NODE 1: Received configuration changes from slave node 6 for node 6 datalen 22415
    13780:20100729:135128.007 NODE 1: Received history_uint from node 3 for node 3 datalen 49617
    13780:20100729:135128.393 NODE 1: Received history_str from node 3 for node 3 datalen 55680
    13780:20100729:135128.496 NODE 1: Received history from node 3 for node 3 datalen 14350
    13780:20100729:135129.986 NODE 1: Received history from node 5 for node 5 datalen 13148
    13780:20100729:135130.114 NODE 1: Received history_uint from node 5 for node 5 datalen 1965
    13780:20100729:135130.138 NODE 1: Received history_str from node 5 for node 5 datalen 3090
    13781:20100729:135132.531 NODE 1: Sending configuration changes to slave node 6 for node 6 datalen 2482236
    13780:20100729:135133.057 NODE 1: Received history from node 2 for node 2 datalen 342439
    13780:20100729:135135.460 NODE 1: Received history_uint from node 2 for node 2 datalen 56536
    13780:20100729:135135.993 NODE 1: Received history_str from node 2 for node 2 datalen 16096
    13781:20100729:135137.532 NODE 1: Error while receiving answer from Node [6] error: ZBX_TCP_READ() failed [Interrupted system call]
    13781:20100729:135138.659 NODE 1: Received history from node 3 for node 3 datalen 28458
    13780:20100729:135138.971 NODE 1: Received history_uint from node 3 for node 3 datalen 4137
    13781:20100729:135139.017 NODE 1: Received history_str from node 3 for node 3 datalen 4764
    13780:20100729:135139.175 NODE 1: Received history from node 5 for node 5 datalen 14013
    13781:20100729:135139.331 NODE 1: Received history_uint from node 5 for node 5 datalen 1810
    13780:20100729:135139.353 NODE 1: Received history_str from node 5 for node 5 datalen 2426
    13781:20100729:135149.389 NODE 1: Received history from node 5 for node 5 datalen 12521
    13780:20100729:135149.531 NODE 1: Received history_uint from node 5 for node 5 datalen 1857
    13781:20100729:135149.554 NODE 1: Received history_str from node 5 for node 5 datalen 2012
    13781:20100729:135158.217 NODE 1: Received configuration changes from slave node 3 for node 3 datalen 6830
    13780:20100729:135159.590 NODE 1: Received history from node 5 for node 5 datalen 13286
    13780:20100729:135159.698 NODE 1: Received history_uint from node 5 for node 5 datalen 1982
    13780:20100729:135159.719 NODE 1: Received history_str from node 5 for node 5 datalen 3334
    13781:20100729:135206.408 NODE 1: Sending configuration changes to slave node 3 for node 3 datalen 6940858
    13781:20100729:135211.409 NODE 1: Error while receiving answer from Node [3] error: ZBX_TCP_READ() failed [Interrupted system call]
    13780:20100729:135211.409 NODE 1: Received configuration changes from slave node 2 for node 2 datalen 2458
    13781:20100729:135211.420 NODE 1: Received history from node 5 for node 5 datalen 12178
    13781:20100729:135212.151 NODE 1: Received history from node 4 for node 4 datalen 36696
    13781:20100729:135212.522 NODE 1: Received history from node 6 for node 6 datalen 343140
    13781:20100729:135215.404 NODE 1: Received history_uint from node 5 for node 5 datalen 2612
    13781:20100729:135215.430 NODE 1: Received history_uint from node 4 for node 4 datalen 4987
    13781:20100729:135215.511 NODE 1: Received history_str from node 4 for node 4 datalen 6864
    13781:20100729:135215.591 NODE 1: Received history from node 4 for node 4 datalen 1920
    13781:20100729:135215.617 NODE 1: Received history_uint from node 6 for node 6 datalen 88777
    13781:20100729:135216.326 NODE 1: Received history_uint from node 4 for node 4 datalen 133
    13781:20100729:135216.327 NODE 1: Received history_str from node 5 for node 5 datalen 3762
    13781:20100729:135216.610 NODE 1: Received history_str from node 6 for node 6 datalen 2342
    13781:20100729:135216.628 NODE 1: Received history_log from node 6 for node 6 datalen 368
    13781:20100729:135216.638 NODE 1: Received history_text from node 6 for node 6 datalen 5518
    13781:20100729:135216.660 NODE 1: Received events from node 6 for node 6 datalen 1446
    13781:20100729:135216.717 NODE 1: Received history from node 6 for node 6 datalen 117457
    13780:20100729:135216.726 NODE 1: Sending configuration changes to slave node 2 for node 2 datalen 5895827
  • jzuilkowski
    • May 2010
    Also, here's a pic of my actions, I couldn't figure out how to get a direct link from flickr
    The safest and most inclusive global community of photography enthusiasts. The best place for inspiration, connection, and sharing!
