I want to ping sub links (URLs) inside a web site using windows curl utility.The site requires login authentication which is done using SAML token process.
Is there a way I can use SAML authentication in curl to login to web site and check the sub link inside web site.
Thanks in advance.
Bapu
Thanks in advance.
Bapu
