sticky alert until acknowledged
  • ghislain
    • Jun 2005
    • 160
    hi,
    i wanted to know how to have a trigger that stay up until acknowledged ?
    for exemple i have an alert for disk utilisation if it drops under 10% free but if the disk free enough space then the alert disapear. What i want is that the alert stay up until i acknowledge it even if the disk is now 80% free
    Is it possible ?
    Regards,
    Ghislain.
  • walterheck
    • Jul 2009
    • 153
    Hi ghislain,
    We do that with recurring alerts. When you set up an action, tick teh box "enable escalation". Then, in the action operations area, put in steps 1-0, which means it will infinitely keep alerting you, and put in a condition there to match "Event acknowledged = "Not Ack"".
    That way, the alert will be sent every time 'Period' number of seconds have passed until it is both resolved and acknowledged. We tweaked it a bit more to only do that for triggers with severity > average to avoid it getting to annoying though
    Walter
    Free and Open Source Zabbix Templates Repository | Hosted Zabbix @ Tribily (http://tribily.com)
    • ghislain
      • Jun 2005
      • 160
      thanks,
      the alert is sending emails but is it showing in the triggers page ?
      you see i have the trigger page openned to see if there is an issue and this is where i wanted to have the alert stay until i ack it.
      Regards,
      Ghislain.
      • walterheck
        • Jul 2009
        • 153
        you see i have the trigger page opened to see if there is an issue and this is where i wanted to have the alert stay until i ack it.
        No, it doesn't show on the triggers page. You could of course modify the source and make that happen, shouldn't be too difficult.
        • ghislain
          • Jun 2005
          • 160
          it would requirre making {TRIGGER.EVENTS.PROBLEM.UNACK} or {EVENT.ACK.STATUS} ( i am not sure ) usable in trigger expression. This i am not able to change in the code myself ^^
          if ( 'last event of this trigger' is unack) then alert stay up
          Regards,
          Ghislain.
          • AVilks
            • Apr 2018
            HI!
            I got same isue: I need the same option, but do not understand how to make the right adjustment, with Zabbix everything is still in the startup stage.
