Set Maintenance remotely
  • rangeshgupta
    • May 2010
    • 21
    We have cluster, which is used by user's for running the jobs. When server are idle we make them shut down and start when there is a job in a queue
    So, the state change of the servers are automated.
    It would be very useful if I can add to script a command to enable maintenance before shutting down the server. And disabled the maintenance while starting the server.
    Is there is a way to do that.
  • ruswold
    • Mar 2010
    • 210
    For disable monitoring (set status not monitored) exec sql query
    update hosts set status = 1 where host = HOSTNAME
    to unable monitoring: update hosts set status = 0 where host = HOSTNAME
    • dpbaker57
      • Aug 2010
      • 33
      Help for those of us who are SQL challenged.
      This would be great if I knew how to set up the SQL connection and could code the change.
      I need to script like this for our java code deployments, temporarily disabling website monitors. The releases are already mostly scripted in windows command (.bat). I also need this when rebooting to apply Windows updates, temporarily disabling host monitors. I guess I will have to run a script on each boot to re-enable monitoring. Most of the people doing the updates are unfamiliar with Zabbix except for the generated alerts.
