Orabbix 11G problem - oracle.jdbc.driver.T4CConnection is closed
  • damianh
    • Feb 2010
    Hello
    I am trying to setup Orabbix for Oracle 11G, however I keep getting error oracle.jdbc.driver.T4CConnection is closed
    Using SQLPLUS I can run the queries with no issue, all I can think of is that the JDBC driver connection has a problem.
    My connection settings look like this:
    CPCS2.Url=jdbcracle:thin:@hostname.mynetwork.com:1521:CPCS2
    I’ve tried using the IP address instead of the name. The hostname is definitely resolving…
    Any suggestions are welcome…
    Thanks,
    Damian
    From the log file:
    2010-08-12 08:49:20,378 [pool-1-thread-1] DEBUG Orabbix - Actual query is dbblockgets statement is select to_char(sum(decode(name,'db block
    gets', value,0))) "block_gets" FROM v$sysstat
    2010-08-12 08:49:20,378 [pool-1-thread-1] ERROR Orabbix - Error on DBEnquiry on query =dbblockgets Error returned is java.sql.SQLException:
    Connection oracle.jdbc.driver.T4CConnection@19b1de is closed.
    2010-08-12 08:49:20,378 [pool-1-thread-1] WARN Orabbix - I'm going to return for query dbblockgets
