Action by trigger from multiple systems
  • Silver
    • Aug 2010
    I despair at the configuration of action by trigger from multiple systems.
    A brief explanation:
    System_A: www.google.de
    System_B: www.web.de
    Item: icmpping
    Trigger: No icmpping available
    Action: Email notification if System_A *AND* System_B not available(ping).
    (System_A: down, System_B: up - NO ACTION; System_A: up, System_B: down - NO ACTION)
    Configuration of action:
    Zabbix get both trigger, but no action occur:
    If I change the type of calculation to *OR*,
    then works it propertly:
    What am I doing wrong?
  • alixen
    • Apr 2006
    • 474
    When both System_A and System_B are unreachable, Zabbix will fire 2 events, one for System_A, the other for System_B.
    Condition "Host=System_A AND Host=SystemB" will never be true since each event is only related to ONE host.
    What you need to do is to define a trigger that depends on both hosts:
    {System_A:icmpping.last(0)}=0 & {System_B:icmpping.last(0)}=0
    Just add it to SystemA.
    You can then remove "Host=System_A AND Host=SystemB" from your alert.
    Regards,
    Alixen
    http://www.alixen.fr/zabbix.html
    • Silver
      • Aug 2010
      Thank you, Alixen!
      It works now.
      Kind regards,
      Silver
