How To Set Up a Zabbix Proxy Tutorial ?
  • webtechengineering
    • May 2010
    Hello!
    Does anyone know of a good tutorial on how to set up a Zabbix Proxy ?
    Thanks in advance
  • forlinuxsupport
    • Oct 2005
    • 39
    have you tried the official docs ?
    see the heading proxy
    http://www.zabbix.com/documentation/...on_from_source
    • Stephen Wood
      • Feb 2012
      • 43
      Before we judge people let's remember that threads such as this often rank high on Google and are the first place people hit when looking to do things like this.
      So for the googlers: the most up-to-date directions for setting up a Zabbix proxy can be found in the documentation here:
      • mrmuff
        • Jul 2015
        Zabbix Proxy install and configuration
        The official docs are unclear on how to install the Proxy role; they are not concise at all. If anyone knows of a good walk-through on how to get a Proxy installed and configured, please share. I have googled this, but again, not finding anything in the way of concise steps on 'here's how you get your proxy working'... thanks!
        • Gsmith
          • Mar 2015
          • 56
          Zabbix Proxy
          I hope this helps,
          I used this demonstration on my CentOS 6.6 Virtual machine.
          And
          It clarified on what I needed to do.
          -GSmitt
          • Tec_Technician
            • Dec 2015
            • 39
            Sorry for the Delay
            Hello;
            I hope it stills help someone , i found this guide:
            It looks like what you was looking for a walk-through on how to get a Proxy installed and configured.
            I just try to follow the steps and right now...i have a doubt in the middle of the process... Do i have to install and configure Zabbix agents on the remote network?Or the Proxy will make the agent function of gathering data??
            Hope to hear from you guys.
            • fj1200
              • Jul 2016
              • 15
              Proxy Disk Size
              Resurrecting an old thread here to keep it all together:
              Can anyone point me in the right direction or tell me how to right-size a Zabbix proxy vm? I cannot find anywhere anything that gives an indication of the vHDD size.
              I can find install instructions, RAM size, CPU core/socket count, IOPS, etc but nothing that gives a disk size.
              Going to be running on CentOS 7 minimal build as per the main Zabbix server.
              The default on ESXi 5.5 for CentOS is 16GB. Since the DB is just a cache and fwds the data to the main server how big do I really need?
