Hi
Im looking around some solution, where i can use "net.if.total[if,<mode>]"
i create by the " Template_SNMPv2_Device" one user define template under SNMP with Titel "Network-Traffic Total".
OID = "interfaces.ifTable.ifEntry.ifTotalOctets.1"
key ="net.if.total[if,bytes]"
example: "net.if.out[,bytes]" is working
Optional:
- How can i create a graph with 24h and not as default by 1 hour ?
- If i have change something by snmp items, have i must to unselect ALL Server, change Items, and select all Server again with this new Feature ?
- it is possible to calculate the value of bytes to kbytes or mbytes ? example "net.if.out[,kbytes]" OR "net.if.out[,mbytes]"
greetings Jochen
Optional:
greetings Jochen
