Dear All,
I plan to use the Zabbix sender protocol in my scripts because not all of my machines are have Z client installed and I do not want to depend on it. To see if I clearly understand how it is works I just did telnet to my zabbix server and copy-pasted the documentation example. Surprisingly I got an OK (I believe because the xml fragment was correct), but the data I posted did not appeared in the latest data screen. Most probably because the test data host, "Sonic server" is not configured on my server.
Questions:
- is the data I posted from a non-existing host in the db?
- is the data I posted for a non-existing key in the db?
- if the data in the db, then it is maintained by the internal mechanisms, so is it purged after the configured time, even if the host and/or the key is not exists?
- if I want to get this data do I have to create all the hosts (yes, I think)
- do I have to create all the keys the client posts? (yes, I think)
- if the data in the db will it available when I create the host/key at a later time?
- Is there any way to automate the host/key creation from command line?
Questions:
