I need to monitor the bandwidth of a remote set of freebsd servers.
My first guess was to use snmp, but it seems I would need the calculate the bandwidth using a formula based on a set of snmp data fields... and I think I can't do it in zabbix...
Other try was to install a zabbix native agent on that machines, but seems that the freebsd agent won't support the netload function...
Any ideas?
Thanks,
Edgar
Any ideas?
Thanks,
Edgar
