Zabbix reporting
I believe this has been asked several times before and always the answer is something similar to: "Use Crystal/Jasper/etc".
But here I go again, is there a way to get better reports from zabbix. For example average CPU utilization from the last month or average memory utilization for X, Y, Z devices.
I see the average on the graphs so is there a way to get that average for all the devices on a group.
This is quite important and the only reason I'm thinking of using another product or something to fullfill this need (Right now, cacti with reportit plugin)
If the only answer is Jasper/Crystal Reports can some body share an example, I've been writing SQL here and there but I'm not quite happy with performance, ease of grouping and such.
Network Map
A nice feature would be to get a dynamically generated network map, something along the lines of netdisco or nedi.
Basically, I love zabbix. It's been one of the fixed tabs on my browsers for the last 3 years and for the moment I keep patching those "feature holes" with the software I mentioned before but it keeps getting harder and harder to do that.
Any help is appreciated.
Network Map
