Maps & Slideshows
  • QwErTy_LoGiC
    • Feb 2010
    • 66
    Maps & Slideshows
    Hi everybody,
    I'm not sureif this is a bug or the intended behavior but when I have a map in a screen during a slideshow, I can't seem to click any elements to expand. The map appears as a simple PNG.
    If this is the intended behavior then I'll make a feature request.
    This is in Chrome and IE.
  • QwErTy_LoGiC
    • Feb 2010
    • 66
    Oh right...
    This is with Zabbix 1.8.3
    • richlv
      • Oct 2005
      • 3112
      well, additionally you can't click on elements like graphs or maps to open them individually.
      for something like 'status of triggers' you can change displayed group or host, but the changes does not stick.
      this probably should be improved, so a feature request would do
      • QwErTy_LoGiC
        • Feb 2010
        • 66
        Feature Request done...
        I made the feature request:
