Agregating results
  • magawake
    • Aug 2010
    • 24
    Agregating results
    Lets say I have 3 snmp OIDs and they produce 3 decimal types. How can I create a logical unit which will have the sum of all three OIDs?
    ________
    FORD 999 SPECIFICATIONS
  • alixen
    • Apr 2006
    • 474
    You can use a calculated item for that : http://www.zabbix.com/documentation/...lculated_items
    Regards,
    Alixen
    http://www.alixen.fr/zabbix.html
    • magawake
      • Aug 2010
      • 24
      Thanks for the response.
      Is there an example anywhere so I can combine eth0 and eth1 to form a logical device bond0? And then graph that?
      ________
      NEW MEXICO MEDICAL MARIJUANA
      • alixen
        • Apr 2006
        • 474
        I don't know but something like:
        last("host:net.if.in[eth0,bytes]")+last("host:net.if.in[eth1,bytes]")
        should give you the sum of input traffic.
        Alternatively, you could just collect net.if.in[bond0,bytes] and graph it.
        Regards,
        Alixen
        • magawake
          • Aug 2010
          • 24
          If I am using snmp, that may not work
          ________
          Volcano Digital
          • alixen
            • Apr 2006
            • 474
            Why not, have you tried it ?
            Regards,
            Alixen
