Hi I would like to disable 1 or more specific host/s triggers - pre an application build run and then enable the host/s triggers once the build finishes - preferably, as a script.
With the above option - I will not get spammed during the Application build window, but will be notified if the server crashes during the build.
Running Zabbix 1.8.1
Thanks in Advance
Thanks in Advance
