Nested Macros
  • abdulshafy
    • Aug 2010
    • 13
    Nested Macros
    Hello all,
    What I need to do is to define some macro in a template in terms of another macro which is defined inside the hosts linked to that template.
    Ex.
    In template:
    {$LANIF} ⇒ 10.{$BN}.1.1
    In a host linked to the template:
    {$BN} ⇒ 55
    I'm not able to do that! and the only thing that works is to define macros to resolve to a static value.
    Any help will be much appreciated.
  • abdulshafy
    • Aug 2010
    • 13
    Still looking for an answer!
    • asaveljevs
      Zabbix developer
      • Feb 2010
      • 36
      This question has recently been brought up internally and we have decided that recursive user macros like the ones you mentioned will not be supported.
      • abdulshafy
        • Aug 2010
        • 13
        Oh it would be very useful! as it would, dramatically, facilitate configuration!, is there any workaround?
        • asaveljevs
          Zabbix developer
          • Feb 2010
          • 36
          Unfortunately, there does not seem to be. One of the reasons why we have decided against is that recursive user macros might slow the frontend significantly.
          • abdulshafy
            • Aug 2010
            • 13
            A better trade-off would be limiting the depth of recursion levels, may be to 1, thus avoiding significant performance degradation.
            • Vaku
              • Feb 2018
              • 24
              But why?
              Grafana supports nested macros. Why you decided to not support this? This just cuts down all the flexibility this functionality could provide.
