simple upgrade to 1.8.3 from 1.8.2
  • woisch
    • May 2009
    • 46
    i have seen this post -> http://www.zabbix.com/forum/showthread.php?t=16540
    Is this the same way how to update zabbix to 1.8.3? Or is there another better way?
    Why there is no update function for zabbix in the frontend?
    woisch
  • tchjts1
    • May 2008
    • 1605
    Yes, same procedure. Although, I would definitely make backup copies of my 1.8.2 binaries and the entire 1.8.2 frontend in case there were issues, you could easily revert to 1.8.2
    I would do something like this for the frontend, which also moves zabbix.conf.php back into play.
    Backup old front-end files, as root:
    cd /var/www
    mv html html.1.8.2
    mkdir /var/www/html
    cp -R /zabbix-1.8.3/frontends/php/* /var/www/html/
    cp /var/www/html.1.8.2/conf/zabbix.conf.php /var/www/html/conf
    • woisch
      • May 2009
      • 46
      thanks for the reply.
      Short question. How could i backup my binaries?
      • tchjts1
        • May 2008
        • 1605
        With the Zabbix processes stopped and before you compile the new binaries...
        cd <dir where your binaries are>
        mv zabbix_server zabbix_server_182
        mv zabbix_agentd zabbix_agentd_182
        mv zabbix_get zabbix_get_182
        mv zabbix_sender zabbix_sender_182
        Then after you install 1.8.3, if you run into any problems where you have to revert back to 1.8.2, you just reverse the entire process and mv the /var/www/html folder to something like /var/www/html_183 and mv the var/www/html_182 folder back to /var/www/html and do the same for the binaries.
