Polling Zabbix from HPOV
  • BonzaiBoy
    • Sep 2010
    I'm planning to install a Zabbix-server for polling my devices.
    The department doing the after-hours monitoring of our network is using HPOV.
    I would like Zabbix to be in charge and I'm looking for a way to let HPOV poll my Zabbix server (thus Zabbix acting as a SNMP-daemon or so).
    I know Zabbix can send traps to HPOV, but the current HPOV requires to be polling itself.
    Can anyone help me out with advice, please ?
    Kind regards,
    Gorik
  • mbrand5371
    • May 2009
    • 55
    Hi Gorik.
    We're currently migrate von HPOV to ZABBIX an so i have some experience with both. In our environment, HPOV is running at HP-UX and ZABBIX at RHEL5.
    I think the easiest way is to install the HPOV Agent on the ZABBIX Server an then:
    Idea 1: create an "action" with "event source" = "trigger".
    This action could issue a remote command using "logger" to send messages to syslog which is monitored by HPOV Agent.
    Idea 2: create an "action" with "event source" = "trigger" too :-)
    But this action is caused to start "opcmsg" as remote command and sends the issue directly to HPOV
    Regards, Marcus
