question on graphs - min,avg, max
  • chriso
    • May 2010
    • 20
    I have a question on the graph for a data item. I'm analyzing both the graph and actual data from the zabbix secion "monitoring -> latest data).
    I don't understand where the graph gets the min/max/avg values for a particular data element, in this case, cpu load.
    When I compare the graph with the actual data points, it just isn't making sense. In this example, at about 7:15 the actual data aligns with the line on the very top, which I thought was "max". If that is true, what do the middle and bottom lines represent? The more I look at it..the actual data and graph lines just don't match. I've attached both my data set and screenshots of the graph.
    If anyone can enlighten me I would be greatly appreciated. Thanks
  • alixen
    • Apr 2006
    • 474
    Zabbix gets these data from trends table.
    This table contains one record per hour with min/avg/max values during that hour.
    Here is an example from my database:
    select i.itemid,
           from_unixtime(clock),
           t.num,
           t.value_min,
           t.value_avg,
           t.value_max
      from hosts h,
           items i,
           trends t
     where i.hostid=h.hostid
       and t.itemid=i.itemid
       and h.host='srv1'
       and i.description='CPU Load'
     order by clock desc
     limit 10;
    | itemid | from_unixtime(clock) | num | value_min | value_avg | value_max |
    |  19571 | 2010-03-31 10:00:00  |  12 |    0.6400 |    1.6033 |    3.2400 |
    |  19571 | 2010-03-31 09:00:00  |  12 |    0.3700 |    1.0092 |    2.0200 |
    |  19571 | 2010-03-31 08:00:00  |  12 |    0.2800 |    0.9067 |    2.6000 |
    |  19571 | 2010-03-31 07:00:00  |  12 |    0.1200 |    0.8250 |    1.7100 |
    |  19571 | 2010-03-31 06:00:00  |  12 |    0.0300 |    0.4567 |    1.2700 |
    |  19571 | 2010-03-31 05:00:00  |  12 |    0.0900 |    0.9100 |    2.1800 |
    |  19571 | 2010-03-31 04:00:00  |  12 |    0.0400 |    0.5200 |    1.8700 |
    |  19571 | 2010-03-31 03:00:00  |  12 |    0.2800 |    1.1008 |    2.5800 |
    |  19571 | 2010-03-31 02:00:00  |  12 |    0.0600 |    0.6783 |    2.1300 |
    |  19571 | 2010-03-31 01:00:00  |  12 |    0.2200 |    0.9392 |    2.5600 |
    Regards,
    Alixen
    http://www.alixen.fr/zabbix.html
