report by OK o PROBLEM how can i decide to add them ?
  • molmi
    • Jul 2010
    • 39
    I created more trigger but I can not understand with that criterion where zabbix add the word "OK" or problems to report ...
    Thanks for help!
  • ruswold
    • Mar 2010
    • 210
    Thanks for help!
    See http://www.zabbix.com/documentation/...onfig/triggers
    PROBLEM Normally means that something happened. For example, processor load is too high. Called TRUE in older Zabbix versions.
    OK This is normal trigger state. Called FALSE in older Zabbix versions.
