how create i treagger for monitor pc uptime > 24 h
  • molmi
    • Jul 2010
    • 39
    For my It green economy i must check the peoplo don't turn off the PC at the end of workday.
    I create this trigger:
    {Template_Windows:system.uptime.last(0)}<1400
    but don't work very well i think there is an sintax error because tha report are more! and if I check uptime of PC is < 24 h..
    help me!
  • alixen
    • Apr 2006
    • 474
    Uptime is number of seconds since last boot.
    You probably want:
    {Template_Windows:system.uptime.last(0)}>86400
    if you want an alert when a PC is ON for more that 24h (24 * 3600 = 86400 s)
    Regards,
    Alixen
    http://www.alixen.fr/zabbix.html
