Automating the creation of web checks
  • yatesco
    • May 2010
    • 23
    Hi all,
    I have a template that contains the (many) Tomcat application deployments. They are link to the Tomcat template and work fine.
    Now I want to create a web check that ensures they are up and running correctly.
    I can do this for one of the machines, but how can I replicate this check to all the hosts in the group? The URL can be derived from the hostname so when I create my steps I would need access to the hostname.
    Does that make sense?
    Col
  • walterheck
    • Jul 2009
    • 153
    Unfortunately for you web checks are currently not templatable. That means your best options are:
    - Using the API to create the WEB checks
    - Scripting an XML file that you can then import at once.
    hth
    Free and Open Source Zabbix Templates Repository | Hosted Zabbix @ Tribily (http://tribily.com)
    • yatesco
      • May 2010
      • 23
      OK - thanks.
