API how to create trigger
  • chemistmail
    • Sep 2010
    Hello all.
    Sorry for my bad english.
    I want to create trigger with API.
    But how?
    I have installed zabcon.
    this code create item
    PHP Code:
    #!/usr/bin/ruby
    require './zabbixapi.rb'
    zbx=ZbxAPI.new(url)
    zbx.login(login,password)
    name = "test"
    hostid = 10161
    item_p
    'description'=>name,
    'key_'=>"my.key",
    'hostid'=>hostid,
    'type'=>'0'
       'data_type'
    =>0,
    'value_type'=>0,
    'units'=>"%"  }
    uid = zabbix.item.create(item_p)
    But how to create trigger.
  • chemistmail
    • Sep 2010
    )) thanks
    PHP Code:
        expression="{#{hostname}:vfs.fs.size[#{disk},pfree].last(0)}<10"
    description="API Free diskspace on {HOSTNAME} volume #{disk}"
    item_t={
    'hostid' => hostid,
    'expression'=>expression,
    'description'=>description,
    'priority'=>HIGH,
    'status'=>ENABLE,
    #    p item_t
    begin
         uid
    = zabbix.trigger.create(item_t)
    p "cant create trigger on #{hostname} disk #{disk}" if uid.nil?
    end
    • xuxf
      • May 2010
      let me try,
      • nelsonab
        • Sep 2006
        • 1233
        looks like you're on the right track. If you have any issues let me know.
        RHCE, author of zbxapi
        • chemistmail
          • Sep 2010
          create trigger
          in zabbixapi.rb comment 2 string
          PHP Code:
              if !resp["error"].nil?
          ##      raise ZbxAPI_GeneralError, resp["error"] # comment it!
          end
          return resp
          ##             rescue Redirect                  # comment it!
          redirects+=1
                               retry
          if redirects<=5
          , "Too many redirects"
          end
          and now
          here script for create check drive on servers
          PHP Code:
          #!/usr/bin/ruby
          zbx=ZbxAPI.new('http://zabbix.server.com')
          zbx.login('login','password')
          # trigger
          HIGH=4
          AVERAGE
          =3
          WARNING
          =2
          INFORMATION
          =1
          ENABLE
          =0
          DISABLE
          =1
          # return hostid
          def hostid_from_hostname(hostname,zabbix)
           for
          host in zabbix.host.get({"extendoutput"=>true,'pattern'=>"#{hostname}"})
               return
          host['hostid']
          end
          end
          def add_disk_check
          (hostname,zabbix)
          # get drive from servers
          ssh=`ssh -o "StrictHostKeyChecking no" -q #{hostname} 'df -l -P -h | tail -n +2' `
          hostid=hostid_from_hostname(hostname,zabbix)
           for
          l in ssh
              disk
          =l.split[5].gsub("/","\/")
          name="API Free diskspace on #{disk}"
          item_p = {
          'key_'=>"vfs.fs.size[#{disk},pfree]",
          'hostid'=>hostid,
          'type'=>'0',
          'data_type'=>0,
          'value_type'=>0,
          'units'=>"%"
          begin
               uid
          p "cant create item on #{hostname} disk #{disk}" if uid.nil?
          end
              expression
          item_t={
          'hostid' => hostid,
          'priority'=>HIGH,
          'status'=>ENABLE,
          begin
               uid
          end
           end
          end
          # now create items and triggers on all servers
          for host in zbx.host.get({"extendoutput"=>true})
          id=host['hostid']
          hostname=host['host']
          puts "#{id} -- #{hostname}"
          add_disk_check(hostname,zbx)
          end
          # the end
          its work.
          I have scripts for create items and triggers for loadaverage and other.
          Now i write script for create items, triggers and graphs for checking openvz user_beancounters.
          I can write it in wiki, but prefer russian langvich. )
          English is not my nature langvich.
          По русски было бы проще.
