single zabbix server and move to proxy later
  • forlinuxsupport
    • Oct 2005
    • 39
    Hi
    Is it possible to start off with a single zabbix server - and then later move to proxy servers as well.
    So we start using a single server - add hosts to it.
    Later we decide to implement a proxy server to offload some of the work.
    Is that easy to do ?
    Cheers
    Andy
  • richlv
    • Oct 2005
    • 3112
    yes, that should be pretty trivial to do, especially if not using active items. if using them, then it's just a simple change in agent config files as well.
    there might be some limitations (like remote commands not supported over proxy currently), but the move itself is very simple.
