How can I configure agent to use UDP?
  • sineex
    • Sep 2010
    Many installation manuals contain the following setting string added to the /etc/services:
    zabbix-agent 10050/udp Zabbix Agent
    But how can I configure agent to use UDP? I want to minimize the overhead of thousands of values submitted to the server. Is it possible in the Zabbix 1.8.x . Can zabbix trapper be configured with the UDP too?
    Thanks in advance.
  • richlv
    • Oct 2005
    • 3112
    nope, udp is not supported. to reduce network overhead, try using active zabbix agent items as much as possible, maybe also consider zabbix proxies
    • sineex
      • Sep 2010
      Thanks for a reply.
      This option can be useful for retrieval of a big amount of non-critical data for statistics. Closing as not implemented.
