I monitor a server with zabbix.
This is a redhat 5 server, with zabbix_agent 1.8.3 and my server is 1.8.3 too.
This server makes synchronisation of some files using ftp.
I made a script to monitor if the synchronisation works, if not it creates a flag file and zabbix monitor if the flag file existes using this command :
zabbix_get -s 192.168.1.30 -I 10.33.0.75 -k vfs.file.exists[/home/adminit/scripts/checksynchro/cdetol.txt].
I made a trigger on it.
But my problem is that the "vfs.file.exists" check answer allways 0 even if the file exists or not.
Is it a known bug or did I made something wrong ?
Thanks for your reply.
