Advanced parsing of SNMP Values / Monitoring partition usage
  • scoopex
    • Sep 2010
    • 9
    In our setup a snmpv2 item provides a string which needs to be analysed in a non trivial way.
    We run hundreds of linux-servers and we want to monitor the partition usage
    of these servers. An already existing net-snmp "extend" returns the following value.
    "79#/:32#/boot:100#/log-local:7#/var:30#/export"
    All of the numbers describe the percentage of filesystem-usage of a certain partition.
    If one of these values excesses 97% a trigger should fire an alert.
    To analyse the percentage-values of the snmp-oid, we need some intelligence at the zabbix server. Is there a possibility to add programmatic intelligence at the zabbix server to derive a status for a trigger?
    Where can i find detailed information about the usage an possibilities regexes in zabbix.
    (The Documentation in the manual is not very useful: http://www.zabbix.com/documentation/...config/regexps)
    Is there a better way to monitor automatically all mounted partitions which are not pseudo-filesystems (like /proc, /dev, /sys, ...)
    Regards
    Marc
  • scoopex
    • Sep 2010
    • 9
    It´s easy - but very intuitive :-)
    Documentation should be enhanced : http://www.zabbix.com/documentation/...config/regexps
    PHP Code:
    1.) Define a regular expression in
         Administration
    => General => Dropdown at the right side => New Regular Expression
    2.
    ) Add a expression :
    Expression: "(100|9[789])#.+?:"
    Expression Type: "RESULT is true"
    3.) Enter test string: "97#/:94#/boot:100#/log-local:7#/var:30#/export:"
    4.) Hit "Test"
    5.) Define a Name: "DiskUsageRegex97"
    6.) Save
    7.
    ) Create a Item which monitors the value to parse
         i
    .e. SNMP OID: NET-SNMP-EXTEND-MIB::nsExtendOutputFull."df/mountpoint/usage"
    8.) Define a trigger with the following expression:
    "{Linux Standard Monitoring:DiskUsage.regexp(@DiskUsageRegex97)}>0"
