I've found that interval of simple check like icmppingloss[,20,500,,5000] depends on the number of hosts. Only one instance of fping tries to ping all host one by one, so it bеcоmes impossible to check each host with 10-second interval if we have for example 100 hosts to check.
Is it possible to use more instances of fping in parallel?
