Configuring AKCP SensorProbe in Zabbix
  • bubune
    • Jul 2010
    • 10
    Hi All,
    I need some help in configuring AKCP SensorProbe for monitoring in Zabbix. I use the Sensorprobe to monitor temperature, humidity, ac/dc voltages. The SensorProbe am using supports SNMP v1 protocols fully.
    Can anyone help me with what to do in terms of the OIDs and the required keys.
    Thanks all.
    Jacob
  • bubune
    • Jul 2010
    • 10
    I've just come across an OID for temperature reading on the AKCP SensorProbe, which is .1.3.6.1.4.1.3854.1.2.2.1.16.1.3.0. What will be the key in the Zabbix Item configuration.
    I tried some keys but it never gave me the correct temperature reading because while the Web Interface of the SensorProbe is reading an average temperature of 28 degrees celsius, I could not interpret the values being registered in Zabbix based on my guessed keys.
    My question is how do i deduce the key in the Zabbix configuration if I know the OID.
    Thanks all.
